Hi there, I couldn’t find the API endpoint that gives me the size of the garden. Something like the max x,y,z that the bot can travel would be fine. Thanks.
@Wathik Good question. I think the reason people have trouble guessing this one is because the garden size is measured in steps rather than MM like people are used to seeing in the Farm Designer.
Here’s an example of how you could change the X axis length via the API:
- Download the
firmware_configJSON object from https://my.farm.bot/api/firmware_config/ - Determine your steps per MM value for the X axis. You can find this value in the
movement_step_per_mm_xfield. For the sake of example, let’s say that yourmovement_step_per_mm_xvalue is 5.0. - Determine the length you want to set your X axis to. For example, let’s say you want to set the X axis length to 1000 (this makes it easier to do math).
- Multiply the desired axis length by the
movement_step_per_mm_x. 1000.0 * 5.0 = 5000.0 - Set
movement_axis_nr_steps_xto the value calculated in step 4. - Perform a PATCH request to
/api/firmware_configwith the new value.
I hope this helps! Let me know if you have any other questions.
Thank you, I will try it out.
