The CALIBRATE function does not work, it throw following error message
CALIBRATE X
Unhandled message: “R08 F22 P141 V8 Q14\r”
CALIBRATE Y
Unhandled message: “R08 F22 P142 V1 Q88\r”
CALIBRATE Z
Unhandled message: “R08 F22 P143 V13 Q89\r”
when I click move Z button, the bot moves a short distance, then motor try to run reversely, then stop.
the message is “holy-pine-229 Doing movement.” and all button are unclickable
There’s a newer FamBot OS version available. You can click UPDATE to upgrade.
Make sure movement and homing work first before trying calibration. The only additional function calibration performs is to find the length of the axis, which is only necessary if you want to enable Stop at Max.
Also, your motor speeds are much too high. Reduce the max speed to around 400 and the min speed to around 50.
