Hi
The scan image button is disabled and I cannot do camera calibration
I am running 1.4 farmduino and fb os 7.0.1
What shd I do?
thanks
Martin
Hi
What shd I do?
thanks
Martin
Thanks for reporting this bug; the issue will be fixed with the next software update. In the meantime you may be able to use the CALIBRATE
button instead, which will take a new image instead of using an old one.
Hi i think i am not able to do that, since i need to first scan image, have 2 objects recognized and only after that the calibrate button can be used…
Tried again today, calibrate button works
