When accessing the image URLs through the https://my.farmbot.io/api/images endpoint, I can only retrieve the last 450 images. Is this an intended limit?
Even when looking through the UI on FarmBot and I move the slider to the “oldest” image I have, it doesn’t show me truly the oldest image I took.
Is the 450 image limit a function of the size of the images? eg: if I take images at higher resolution, will the limit now be less than 450 images because their file size is larger.
How do I access the older images, beyond the 450th?
Thank you.
