Change wifi network
Hi Farmbot!
Our school has just informed me the wireless network our farmbot (G1.6) is connected to will be discontinued. I would like to connect the bot to a different wifi network. What are the steps? I can find all sorts of stuff about factory resetting and flashing the SD card, but not a clear set of steps on how to do that and it seems a bit much to just change the network used. The Farmbot-xxxx network does not show up at the moment. It did during the initial configuration. Everything is still working perfectly well at the moment.
Can someone set me on the right path?
Thank you!
– Jac (Farmbot @unishanoi.org)
Hi @farmbotatunishanoi
Simplest (non-geeky) option is to SOFT RESET your bot.
Search top Settings menu, e.g.
