When configuring a development environment for a FarmBot on my computer, how do I set the MQTT_HOST and API_HOST IP settings?
Should I add the static IP of docker to docker-compose?
@soungno You need to use an IP address that is accessible from anywhere within your LAN because these IPs will be accessed not only by docker, but also a web browser and a device (which might not be on the same machine as the server).
This means that you can’t use things like 0.0.0.0, localhost, etc…
