Hello,
I installed new MIPI camera (rpi camera v2 - the 8 Mpixel). I was capable to take a many pictures with my setup. Unfortunately now I see following error literaly floading my log :
3 | Error | Upload Error (/tmp/images/capture_1661944188.jpg): {:error, “<?xml version=‘1.0’ encoding=‘UTF-8’?>EntityTooLargeYour proposed upload is larger than the maximum object size specified in your Policy Document.
Content-length exceeds upper bound on range”}
(6500, 400, 0) Aug 31, 13:23
1 | Error | Failed to upload image (HTTP: 400): “<?xml version=‘1.0’ encoding=‘UTF-8’?>EntityTooLargeYour proposed upload is larger than the maximum object size specified in your Policy Document.Content-length exceeds upper bound on range”
… Probably wrong place where image compression does not work well (empty place with sand…).
I assume there left some pictures on my farmbot and it is unable to upload or remove them.
Am I right ?
Would be possible to raise the image size quota ?
Or provide instructions how to wipe the files from the raspbrry without powering the machine off ?
Interresting thing is that camera calibration on this place passed and uploaded the image… Take picture feature failed.
I found no jpegs on the SD-card. I assume it save them on /tmp. I see no errors in the log afret system reboot.
Image size solved temporarily by blank sheet of paper (which compensates the compensation issue).
Hi @jan.janson you’ll probably need to get a FarmBot Inc developer involved to change image-file size limits [ the photo image files are staged temporarily on the bot RPi until uploaded ( by a transient background task ) to Google Cloud storage assigned to FarmBot Inc. ( publicly accessible with the storage URLs saved in the Web App API for your photos ) ]
Hi, still no response form farmbot team?
Camera failing, rpi camera v2 is listed in supported cameras but image size is unsupproted by the server.
Please help me fix it.
I will try setup my own server, but nodejs is not… how to say that… OK we are between SW engineers, right? so directly… is piece of shit.
@jan.janson No. That’s way more than my stomach wants to deal with a.t.m.
Seems like Web App Self-Hosting is not a high priority for “the FarmBot Team” ( 2 persons ? ) as there’s probably negative reward for effort in supporting it.
Maybe you could open a new Topic to muster the attention of all_Self-Host_ -ers ?
To all self-host-ers…
Use Farmbot-Web-App, in combination with ubuntu 18.04 (yes I know… obsolete).
Follow the installation script and check my thread.
No MQTT or postgres extra installation steps are required.
Do not worry, all works ans is OK.
Jan
