Hi Team,
I am looking at building a Device here in Brisbane Australia and had a question in regards to the size of the device. Could you see any issues in running a device 800mm x 6000mm (so around the same area as the 1500x3000 just thinner)?
On a separate note I can’t find much doco on what type of plants are best suited for farmbot and if a taller device would be beneficial. Do you have any advice around this?
I will most likely start to order the required parts over the next couple of weeks and start the build process shortly after.
-Peter
