Im having an error when I enter the command rails api:start
this is the error message
in
W, [2018-03-26T20:55:45.619507 #32415] WARN -- : [SKYLIGHT] [1.6.0] Running Skylight in development mode. No data will be reported until you deploy your app. (To disable this message for all local apps, run
skylight disable_dev_warning.) PORT=3000 bundle exec foreman start --procfile=Procfile.dev 20:55:48 rails.1 | started with pid 32444 20:55:48 webpack.1 | started with pid 32445 20:55:48 worker.1 | started with pid 32447 20:55:48 logger.1 | started with pid 32448 20:55:52 webpack.1 | 20:55:52 webpack.1 | 20:55:52 webpack.1 | WEBPACK IS RUNNING IN dev MODE. 20:55:52 webpack.1 | 20:55:52 webpack.1 | 20:55:53 webpack.1 | Project is running at http://0.0.0.0:3808/ 20:55:53 webpack.1 | webpack output is served from //192.168.254.111:3808/webpack/ 20:56:03 worker.1 | W, [2018-03-26T20:56:03.582926 #32447] WARN -- : [SKYLIGHT] [1.6.0] Running Skylight in development mode. No data will be reported until you deploy your app. 20:56:03 worker.1 | (To disable this message for all local apps, run
skylight disable_dev_warning.) 20:56:04 logger.1 | W, [2018-03-26T20:56:04.043831 #32448] WARN -- : [SKYLIGHT] [1.6.0] Running Skylight in development mode. No data will be reported until you deploy your app. 20:56:04 logger.1 | (To disable this message for all local apps, run
skylight disable_dev_warning.) 20:56:04 worker.1 | [Worker(host:nicho-Aspire-E5-521 pid:32447)] Starting job worker 20:56:04 worker.1 | 2018-03-26T20:56:04+0800: [Worker(host:nicho-Aspire-E5-521 pid:32447)] Starting job worker 20:56:04 rails.1 | W, [2018-03-26T20:56:04.416530 #32446] WARN -- : [SKYLIGHT] [1.6.0] Running Skylight in development mode. No data will be reported until you deploy your app. 20:56:04 rails.1 | (To disable this message for all local apps, run
skylight disable_dev_warning.) 20:56:04 worker.1 | [Worker(host:nicho-Aspire-E5-521 pid:32447)] Error while reserving job: PG::UndefinedTable: ERROR: relation "delayed_jobs" does not exist 20:56:04 worker.1 | LINE 8: WHERE a.attrelid = '"delayed_jobs"'::regclass 20:56:04 worker.1 | ^ 20:56:04 worker.1 | : SELECT a.attname, format_type(a.atttypid, a.atttypmod), 20:56:04 worker.1 | pg_get_expr(d.adbin, d.adrelid), a.attnotnull, a.atttypid, a.atttypmod, 20:56:04 worker.1 | c.collname, col_description(a.attrelid, a.attnum) AS comment 20:56:04 worker.1 | FROM pg_attribute a 20:56:04 worker.1 | LEFT JOIN pg_attrdef d ON a.attrelid = d.adrelid AND a.attnum = d.adnum 20:56:04 worker.1 | LEFT JOIN pg_type t ON a.atttypid = t.oid 20:56:04 worker.1 | LEFT JOIN pg_collation c ON a.attcollation = c.oid AND a.attcollation <> t.typcollation 20:56:04 worker.1 | WHERE a.attrelid = '"delayed_jobs"'::regclass 20:56:04 worker.1 | AND a.attnum > 0 AND NOT a.attisdropped 20:56:04 worker.1 | ORDER BY a.attnum 20:56:04 logger.1 | I, [2018-03-26T20:56:04.896985 #32448] INFO -- #<Bunny::Session:0x5893758 guest@localhost:5672, vhost=/, addresses=[localhost:5672]>: Heartbeat interval used (in seconds): 10 20:56:05 rails.1 | A server is already running. Check /home/nicho/Dir/Farmbot-Web-App/tmp/pids/server.pid. 20:56:05 rails.1 | => Booting Thin 20:56:05 rails.1 | => Rails 5.1.5 application starting in development on http://0.0.0.0:3000 20:56:05 rails.1 | => Run
rails server -hfor more startup options 20:56:05 rails.1 | Exiting 20:56:05 rails.1 | exited with code 1 20:56:05 system | sending SIGTERM to all processes 20:56:05 worker.1 | [Worker(host:nicho-Aspire-E5-521 pid:32447)] Exiting... 20:56:06 logger.1 | terminated by SIGTERM 20:56:09 worker.1 | rake aborted! 20:56:09 worker.1 | ActiveRecord::StatementInvalid: PG::UndefinedTable: ERROR: relation "delayed_jobs" does not exist 20:56:09 worker.1 | LINE 8: WHERE a.attrelid = '"delayed_jobs"'::regclass 20:56:09 worker.1 | ^ 20:56:09 worker.1 | : SELECT a.attname, format_type(a.atttypid, a.atttypmod), 20:56:09 worker.1 | pg_get_expr(d.adbin, d.adrelid), a.attnotnull, a.atttypid, a.atttypmod, 20:56:09 worker.1 | c.collname, col_description(a.attrelid, a.attnum) AS comment 20:56:09 worker.1 | FROM pg_attribute a 20:56:09 worker.1 | LEFT JOIN pg_attrdef d ON a.attrelid = d.adrelid AND a.attnum = d.adnum 20:56:09 worker.1 | LEFT JOIN pg_type t ON a.atttypid = t.oid 20:56:09 worker.1 | LEFT JOIN pg_collation c ON a.attcollation = c.oid AND a.attcollation <> t.typcollation 20:56:09 worker.1 | WHERE a.attrelid = '"delayed_jobs"'::regclass 20:56:09 worker.1 | AND a.attnum > 0 AND NOT a.attisdropped 20:56:09 worker.1 | ORDER BY a.attnum 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/connection_adapters/postgresql/database_statements.rb:61:in
async_exec’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/connection_adapters/postgresql/database_statements.rb:61:in block (2 levels) in query' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activesupport-5.1.5/lib/active_support/dependencies/interlock.rb:46:in
block in permit_concurrent_loads’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activesupport-5.1.5/lib/active_support/concurrency/share_lock.rb:185:in yield_shares' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activesupport-5.1.5/lib/active_support/dependencies/interlock.rb:45:in
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/connection_adapters/postgresql/database_statements.rb:60:in block in query' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/connection_adapters/abstract_adapter.rb:613:in
block (2 levels) in log’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/connection_adapters/abstract_adapter.rb:612:in block in log' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activesupport-5.1.5/lib/active_support/notifications/instrumenter.rb:21:in
instrument’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/connection_adapters/abstract_adapter.rb:604:in log' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/connection_adapters/postgresql/database_statements.rb:59:in
query’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/connection_adapters/postgresql_adapter.rb:765:in column_definitions' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/connection_adapters/abstract_adapter.rb:167:in
columns’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/connection_adapters/schema_cache.rb:67:in columns' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/connection_adapters/schema_cache.rb:73:in
columns_hash’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/model_schema.rb:471:in load_schema!' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/attributes.rb:233:in
load_schema!'
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/attribute_decorators.rb:50:in load_schema!' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/model_schema.rb:464:in
block in load_schema’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/model_schema.rb:461:in load_schema' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/model_schema.rb:353:in
attribute_types’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/model_schema.rb:376:in type_for_attribute' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/table_metadata.rb:32:in
type’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/relation/predicate_builder.rb:168:in build_bind_param' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/relation/predicate_builder.rb:114:in
block in create_binds_for_hash’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/relation/predicate_builder.rb:89:in each' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/relation/predicate_builder.rb:89:in
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/relation/predicate_builder.rb:34:in create_binds' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/relation/where_clause_factory.rb:21:in
build’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/relation/query_methods.rb:612:in where!' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/relation/query_methods.rb:605:in
where’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/querying.rb:10:in where' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/delayed_job_active_record-4.1.2/lib/delayed/backend/active_record.rb:61:in
clear_locks!'
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/delayed_job-4.1.4/lib/delayed/plugins/clear_locks.rb:9:in block (2 levels) in <class:ClearLocks>' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/delayed_job-4.1.4/lib/delayed/lifecycle.rb:79:in
block (2 levels) in add’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/delayed_job-4.1.4/lib/delayed/lifecycle.rb:61:in block in initialize' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/delayed_job-4.1.4/lib/delayed/lifecycle.rb:79:in
block in add’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/delayed_job-4.1.4/lib/delayed/lifecycle.rb:66:in execute' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/delayed_job-4.1.4/lib/delayed/lifecycle.rb:40:in
run_callbacks’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/delayed_job-4.1.4/lib/delayed/worker.rb:171:in start' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/delayed_job-4.1.4/lib/delayed/tasks.rb:9:in
block (2 levels) in <top (required)>'
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/rake-12.3.1/exe/rake:27:in <top (required)>' 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/bin/ruby_executable_hooks:15:in
eval’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/bin/ruby_executable_hooks:15:in <main>' 20:56:09 worker.1 | 20:56:09 worker.1 | Caused by: 20:56:09 worker.1 | PG::UndefinedTable: ERROR: relation "delayed_jobs" does not exist 20:56:09 worker.1 | LINE 8: WHERE a.attrelid = '"delayed_jobs"'::regclass 20:56:09 worker.1 | ^ 20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/activerecord-5.1.5/lib/active_record/connection_adapters/postgresql/database_statements.rb:61:in
async_exec’
instrument’
query’
columns’
columns_hash’
load_schema!'
attribute_types’
type’
build’
where’
clear_locks!‘
block in add’
run_callbacks’
block (2 levels) in <top (required)>‘
eval’
20:56:09 worker.1 | /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/bin/ruby_executable_hooks:15:in <main>' 20:56:09 worker.1 | Tasks: TOP => jobs:work 20:56:09 worker.1 | (See full trace by running task with --trace) 20:56:09 worker.1 | exited with code 1 20:56:10 system | sending SIGKILL to all processes rails aborted! Command failed with status (1): [PORT=3000 bundle exec foreman start --proc...] /home/nicho/Dir/Farmbot-Web-App/lib/tasks/api.rake:12:in
block (2 levels) in <top (required)>’
/home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/railties-5.1.5/lib/rails/commands/rake/rake_command.rb:21:in block in perform' /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/railties-5.1.5/lib/rails/commands/rake/rake_command.rb:18:in
perform’
/home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/railties-5.1.5/lib/rails/command.rb:46:in invoke' /home/nicho/.rvm/gems/ruby-2.5.0@farmbot-web-app/gems/railties-5.1.5/lib/rails/commands.rb:16:in
<top (required)>'
bin/rails:4:in require' bin/rails:4:in
Tasks: TOP => api:start
I dont know what is the cause of the error.
