I am forever trying to get my FarmBot up and running,
I have had issues connecting through the Wifi as was too far from the router… So I’ve wired ethernet to the farmbot but I when I plyug it in the data lights do not come on and I can’t find a way to get it connected?
It seems to be the port because I have full internet access when I plug in the cable. I had a replacement Farmduino board as I have the Express XL and it kept rebooting, and tried that one too which which had the same issue. So could this be a problem with the raspberry pi? It’s a Rpi Zero
I found a little success by connecting the ethernet cable via an adapter and plugged it into the usb c port on the farmduino board. Now the data lights come on but I can’t seem to get it working through the setup configuration.
The Farmduino Express firmware has no support for Ethernet adapters. You need to connect to the Raspberry Pi Zero.
Unless you have a v1.1 Express XL, you might be out of luck … the v1.1 comes with a Raspberry Pi Zero 2 W which does support Ethernet over a USB adapter.
In either case, there is just 1 USB port on the RPi Zero W so you need to use a USB Hub so that you have 2 ports (1 for Camera plus 1 for Ethernet adapter)
