As suggested by @RickCarlino, here is a loose translation from Python to Node.js ( in CoffeeScript )
of the publish_example.py
program from FarmBot-Python-Examples suite.
# A loose translation of the Python example 'publish_example.py'
# in FarmBot-Labs/FarmBot-Python-Examples repository
# to Node.js and CoffeeScript
# John Simmonds 2019-11-13
# Flow:
# * Request a FarmBot web token
# * Connect to the FarmBot MQTT server over Secure Web Sockets
# * Subscribe to 1 topic
# * Every 5 seconds, Publish a 'toggle_pin' RPC to 1 topic
# Comment: At line 39, edit-in appropriate values for
# Your current FarmBot WebApp Account credentials
mqtt = require 'mqtt'
util = require 'util'
cs_toggle_pin = JSON.stringify {
"kind": "rpc_request",
"args": {
"label": "cb78760b-d2f7-4dd1-b8ad-ce0626b3ba53"
"body": [{
"kind": "toggle_pin",
"args": {
"pin_number": 2
# Fetch a FarmBot JWT via the FarmBot API
fb_api_client = (require 'restify-clients').createJsonClient {url: 'https://my.farm.bot'}
fb_api_client.post '/api/tokens', {"user":{"email":"farmbot-user","password":"farmbot-user-password-cleartext"}}, (err, req, res, obj) ->
unless err
util.log('Starting MQTT work')
mqtt_client = mqtt.connect obj.token.unencoded.mqtt_ws, {username: obj.token.unencoded.bot, password: obj.token.encoded}
mqtt_client.on 'connect', (connack) ->
util.log "-- connect -- #{util.inspect connack}"
mqtt_client.subscribe "bot/#{obj.token.unencoded.bot}/from_device", {}, (err, subs) ->
util.log " -- granted subs -- #{util.inspect subs, {depth: 6}}"
pub_times = setInterval () =>
mqtt_client.publish "bot/#{obj.token.unencoded.bot}/from_clients", cs_toggle_pin, {}, (err) ->
if err
util.log " -- publish err -- #{util.inspect err, {depth: 6}}"
else
util.log " -- publish to bot/#{obj.token.unencoded.bot}/from_clients"
, 5000
mqtt_client.on 'message', (topic, message, packet) ->
util.log "-- message -- #{util.inspect topic}"
util.log " #{util.inspect JSON.parse(message.toString()), {depth: 6}}"
mqtt_client.on 'reconnect', () ->
util.log '-- re-connect --'
else
util.log "#{err}"
