How tall should i make my raised bed for the express xl?
@Coopcity625 300mm or about one foot. The full documentation is available here: Building a Fixed Raised Bed | FarmBot Express Documentation
Make sure when you build, the that the sides are straight as an arrow. If they are bowed by more than 1cm, the Farmbot Express will at a minimum bind and at worst, will fall off the top of the board. And once they are straight, run several aircraft wires or threaded rods across the width to make sure that the sides will not bow in the future. Even doing that, mine falls off or binds every second or third run down the x axis.
