ardun
1
i just water it
FARM EVENT RUNNER DIED. {:UNDEF, [{NIL, :BODY, [], []}, {ENUM, :"-MAP/2-LISTS^MAP/1-0-", 2, [FILE: ‘LIB/ENUM.EX’, LINE: 1229]}, {FARMBOT.FARMEVENT.RUNNER, :HANDLE_INFO, 2, [FILE: ‘LIB/FARMBOT/FARM_EVENT/RUNNER.EX’, LINE: 63]}, {:GEN_SERVER, :TRY_DISPATCH, 4, [FILE: ‘GEN_SERVER.ERL’, LINE: 601]}, {:GEN_SERVER, :HANDLE_MSG, 5, [FILE: ‘GEN_SERVER.ERL’, LINE: 667]}, {:PROC_LIB, :INIT_P_DO_APPLY, 3, [FILE: ‘PROC_LIB.ERL’, LINE: 247]}]}
Please provide some more information if you can:
- Which release of FarmBot OS are you using? (Or, if you built your own, which commit did you use?)
- Are you using my.farmbot.io? (Or, if you are self-hosting, which commit?)
- What are the details of the Farm Event or Sequence that you ran that resulted in the error message? (Or, what do I need to do to get the same error?)
ardun
3
FarmBot OS 4.0 because i can update with my.farmbot.io!
yes,i used my.farmbot.io
i do the Sequence about water !about 3 Sequence !but when it finish it show this!
i have try restart but no use
