when programming events and the same thing happens to me, it does not perform any action. Any solution to the problem. please help
Hi @Cris7 Is your Farm Event a Sequence or a Regimen ?
If it’s a Sequence, does it execute correctly by running it manually ? ( press RUN on sequence page )
yes, when running it works normally, but when programming the event it doesn’t work
I tried both modes and nothing, it doesn’t run alone, all manual
@Cris7 please show us how to reproduce the issue that you are having, and tell us what FarmbotOS version and Farmbot device you are using.
Also, I’m interested to see
- The detail of the Sequence you are wanting to schedule
- A screen-shot of the Farm Event as you create it, for example
I share the requested information. It still does not comply with the programmed orders, but it works with the “RUN” button
Versión: v15.4.1
Modelo: Genesis v1.6
Firmware: v6.6.22 Farmduino (Genesis v1.6)
No, that’s not a relevant problem (though, maybe the underlying code could be refactored a little).
Please post any log records that appear between 12:55PM and 1:05PM ( i.e. covering the Event start time )
While you’re logged-in with the Web App, use this link to see those logs Logs - FarmBot
