Our FarmBot Genesis started moving very slowly after a software update. Also, at the same time as the update, the part of the motor that the band rests on was over tightened (It has now been loosened). I am not sure if the software or the over-tightening caused the issue (it still moves slowly).
The current settings are attached and they are the same as before the update (I think).
Could changing the motor current help?
(Edit: I would also like to mention that the instructions sent to the robotic for the recorded movement was 1000mm in x direction)
@chrisfurlong03
Those motor settings look OK. Changing the current might help, but be careful not to set it too high to avoid overheating the motors (Eg: try to stay under 1200).
A few questions:
- What hardware version are you running?
- Are you using non-supported stepper drivers? Eg: Are you using any parts that were not supplied by FarmBot, Inc.? We’ve received one report this month from a user that had non-standard stepper drivers installed and noticed .
- What version of FarmBot OS were you running prior to the upgrade? Had it been a very long time since you last performed a software update?
Please send this information to support@farmbot.io
along with either an order number or the email address associated with the purchase. We would be happy to continue helping you calibrate the motors, but we no longer provide motor calibration support via the forum.
