We are making a farmbot of size 1.5m x 1.2m. Can I use your software system for reduced sclae also. If not then what should I do? And if Yes ,how will I be able to use it? @roryaronson RickCarlino @TopperWH @SimonWetherley @connor
The software will work just fine with a FarmBot of that size. Once your hardware is built, you can use the calibration feature so the bot can automatically figure out it’s max length and width. Note: rotary encoders or endstops are required for this functionality.
