Hi,
Tried my first seed planting last weekend and didn’t manage to get a single one . . but ran out of time to collect the information.
Here is a link to a video. There are about 3 different scenarios but all result in a reboot
Farbmot descends to 50 mm above seed bin, turns on vacuum pump, descends into seed bin and seed attaches. Then Farmbot reboots (vacuum pump left on)
Same thing except the Farmbot is able to ascend back to near the high point Z axis where it travels and then reboots (vacuum pump left on).
Same thing as 2 except when it reboots the pump turns off.
Video of scenario 3 is at https://youtu.be/esE0-BbZMqQ.
Farmbot firmware is up to date and recently flashed
I actually don’t have any events scheduled Last year I had a problem with my Farmbot sporadically rebooting. Even though I never had an excessive amount of events, reducing them worked around the issue.
I appreciate any help.
Thanks
Jack
I captured a log as well
00:24:10.804 [info] CeleryScript ok [#Reference<0.3272493800.537395201.253787>]:
00:24:24.695 [info] Finding home on the Z axis
00:24:48.851 [info] Finding home on the X axis
00:24:59.107 [info] Finding home on the Y axis
00:25:25.641 [info] Moving to (50, 0, 0)
00:25:28.575 [info] Setting device mounted tool ID to 11119
00:25:28.890 [info] Moving to (50, 0, 0)
00:25:29.461 [info] Moving to (3.4, 1050, 0)
00:25:46.867 [info] Moving to (3.4, 1050, -284)
00:26:08.416 [info] The Vacuum peripheral value is ON (digital)
00:26:08.490 [info] Moving to (3.4, 1050, -334)
00:26:12.252 [info] usb 1-1.2: reset high-speed USB device number 26 using dwc_otg
00:26:15.066 [info] usb 1-1.2: reset high-speed USB device number 26 using dwc_otg
00:26:17.882 [info] usb 1-1.2: reset high-speed USB device number 26 using dwc_otg
00:26:20.212 [info] usb 1-1.2: reset high-speed USB device number 26 using dwc_otg
00:26:21.571 [info] Moving to (3.4, 1050, 0)
00:26:23.002 [info] usb 1-1.2: reset high-speed USB device number 26 using dwc_otg
00:26:25.822 [info] usb 1-1.2: reset high-speed USB device number 26 using dwc_otg
00:26:27.022 [info] usb 1-1.2: USB disconnect, device number 26
00:26:27.386 [info] usb 1-1.2: new high-speed USB device number 27 using dwc_otg
00:26:27.746 [info] usb 1-1.2: New USB device found, idVendor=1908, idProduct=2311, bcdDevice= 1.00
00:26:27.747 [info] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
00:26:27.747 [info] usb 1-1.2: Product: USB2.0 PC CAMERA
00:26:27.747 [info] usb 1-1.2: Manufacturer: Generic
00:26:27.747 [info] uvcvideo: Found UVC 1.00 device USB2.0 PC CAMERA (1908:2311)
00:26:27.747 [warn] uvcvideo 1-1.2:1.0: Entity type for entity Processing 2 was not initialized!
00:26:27.747 [warn] uvcvideo 1-1.2:1.0: Entity type for entity Camera 1 was not initialized!
00:26:27.747 [info] input: USB2.0 PC CAMERA: USB2.0 PC CAM as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input13
00:26:29.912 [info] usb 1-1.2: reset high-speed USB device number 27 using dwc_otg
00:26:32.731 [info] usb 1-1.2: reset high-speed USB device number 27 using dwc_otg
00:26:35.542 [info] usb 1-1.2: reset high-speed USB device number 27 using dwc_otg
00:26:38.362 [info] usb 1-1.2: reset high-speed USB device number 27 using dwc_otg
00:26:39.782 [info] RouteManager: set_connection_status eth0 → :disconnected
00:26:39.783 [error] usb usb1-port1: disabled by hub (EMI?), re-enabling…
00:26:39.783 [info] usb 1-1: USB disconnect, device number 2
00:26:39.783 [info] usb 1-1.1: USB disconnect, device number 3
00:26:39.783 [warn] WARN::dwc_otg_hcd_urb_dequeue:638: Timed out waiting for FSM NP transfer to complete on 1
00:26:39.784 [info] smsc95xx 1-1.1:1.0 eth0: unregister ‘smsc95xx’ usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet
00:26:39.784 [info] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
00:26:39.786 [debug] VintageNet(eth0): :configured → eth0 removed
00:26:39.790 [error] Child :undefined of Supervisor MdnsLite.ResponderSupervisor terminated
** (exit) normal
Pid: #PID<0.1165.0>
Start Call: MdnsLite.Responder.start_link({192, 168, 10, 83})
Restart: :permanent
Shutdown: 5000
Type: :worker
00:26:39.797 [error] Child :undefined of Supervisor MdnsLite.ResponderSupervisor terminated
** (exit) normal
Pid: #PID<0.6846.0>
Restart: :permanent
Shutdown: 5000
Type: :worker
00:26:39.834 [info] Interface eth0 disconnected from access point
00:26:39.845 [info] usb 1-1.2: USB disconnect, device number 27
00:26:39.859 [warn] route_manager(clear_a_local_route): ignoring failure “ip: can’t find device ‘eth0’\n”
00:26:39.887 [debug] ip:ip: can’t find device ‘eth0’
00:26:39.889 [info] Farmbot has been reconnected. Canceling scheduled factory reset
00:26:39.898 [warn] route_manager(clear_a_local_route): ignoring failure “ip: can’t find device ‘eth0’\n”
00:26:39.926 [debug] ip:ip: SIOCGIFFLAGS: No such device
00:26:39.930 [warn] route_manager(clear_a_route): ignoring failure “ip: can’t find device ‘eth0’\n”
00:26:39.948 [warn] route_manager(clear_a_route): ignoring failure “ip: can’t find device ‘eth0’\n”
00:26:39.954 [error] Nonzero exit from ip, [“link”, “set”, “eth0”, “down”]: 2
00:26:39.955 [info] FarmBot will factory reset in 50 minutes if the network does not reassociate. If you see this message directly after configuration, this message can be safely ignored.
00:26:39.956 [debug] Unknown property change: [“interface”, “eth0”, “addresses”]
old:
[%{address: {192, 168, 10, 83}, family: :inet, netmask: {255, 255, 255, 0}, prefix_length: 24, scope: :universe}, %{address: {65152, 0, 0, 0, 47655, 60415, 65208, 48475}, family: :inet6, netmask: {65535, 65535, 65535, 65535, 0, 0, 0, 0}, prefix_length: 64, scope: :link}]
new:
[%{address: {192, 168, 10, 83}, family: :inet, netmask: {255, 255, 255, 0}, prefix_length: 24, scope: :universe}]
old:
new:
00:26:39.956 [debug] Unknown property change: [“interface”, “eth0”, “present”]
old:
true
new:
nil
00:26:39.957 [debug] Unknown property change: [“interface”, “eth0”, “hw_path”]
old:
“/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1:1.0”
new:
nil
00:26:39.957 [debug] Unknown property change: [“interface”, “eth0”, “lower_up”]
old:
false
new:
nil
00:26:39.957 [debug] Unknown property change: [“interface”, “eth0”, “mac_address”]
old:
“b8:27:eb:b8:bd:5b”
new:
nil
00:26:39.957 [debug] Unknown property change: [“interface”, “eth0”, “addresses”]
old:
new:
nil
00:26:39.957 [debug] Unknown property change: [“interface”, “eth0”, “state”]
old:
:configured
new:
:reconfiguring
00:26:39.958 [debug] VintageNet(eth0): :reconfiguring → done error
00:26:39.989 [info] usb 1-1.5: USB disconnect, device number 24
00:26:39.989 [error] cdc_acm 1-1.5:1.0: failed to set dtr/rts
00:26:39.991 [error] GenServer #PID<0.5022.0> terminating
** (stop) {:uart_error, :eio}
Last message: {:circuits_uart, “ttyACM0”, {:error, :eio}}
State: %{device: “ttyACM0”, handle_gcode: #Function<32.33254120/1 in FarmbotFirmware.init/1>, open: true, reset: FarmbotCore.FirmwareResetter, uart: #PID<0.5023.0>}
00:26:39.992 [warn] WARN::dwc_otg_hcd_urb_dequeue:638: Timed out waiting for FSM NP transfer to complete on 2
00:26:39.993 [info] Interface eth0 disconnected from the internet: disconnected
00:26:39.995 [error] Process #PID<0.5022.0> terminating
** (exit) {:uart_error, :eio}
(stdlib 3.14) gen_server.erl:805: :gen_server.handle_common_reply/8
(stdlib 3.14) proc_lib.erl:226: :proc_lib.init_p_do_apply/3
Initial Call: FarmbotFirmware.UARTTransport.init/1
Ancestors: [FarmbotFirmware, FarmbotCore, #PID<0.339.0>]
Message Queue Length: 0
Messages: []
Links: [#PID<0.5021.0>]
Dictionary: []
Trapping Exits: false
Status: :running
Heap Size: 2586
Stack Size: 28
Reductions: 586608
Neighbours:
FarmbotFirmware (#PID<0.5021.0>)
Initial Call: FarmbotFirmware.init/1
Current Call: :gen_server.loop/7
Ancestors: [FarmbotCore, #PID<0.339.0>]
Links: [#PID<0.340.0>, #PID<0.5022.0>]
Status: :waiting
Heap Size: 6772
Stack Size: 12
Reductions: 270265
Current Stacktrace:
(stdlib 3.14) gen_server.erl:437: :gen_server.loop/7
00:26:39.996 [debug] Unknown property change: [“interface”, “eth0”, “state”]
old:
:reconfiguring
new:
:retrying
00:26:39.996 [error] Child FarmbotFirmware of Supervisor FarmbotCore terminated
Pid: #PID<0.5021.0>
Start Call: FarmbotFirmware.start_link([transport: FarmbotFirmware.StubTransport, side_effects: FarmbotCore.FirmwareSideEffects, reset: FarmbotCore.FirmwareResetter])
Restart: :permanent
Shutdown: 5000
Type: :worker
00:26:39.997 [info] Child FarmbotFirmware of Supervisor FarmbotCore started
Pid: #PID<0.6852.0>
Restart: :permanent
Shutdown: 5000
Type: :worker
00:26:40.000 [debug] firmware state change: transport_boot => boot
00:26:40.002 [error] Error opening ttyACM0: :enoent
00:26:40.015 [error] (Rollbax) connection error: :nxdomain
00:26:40.192 [warn] Indeed it is in host mode hprt0 = 00001501
00:26:40.402 [info] usb 1-1: new high-speed USB device number 28 using dwc_otg
00:26:40.402 [warn] Indeed it is in host mode hprt0 = 00001101
00:26:40.642 [info] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
00:26:40.642 [info] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
00:26:40.642 [info] hub 1-1:1.0: USB hub found
00:26:40.642 [info] hub 1-1:1.0: 5 ports detected
00:26:40.962 [info] usb 1-1.1: new high-speed USB device number 29 using dwc_otg
00:26:41.102 [info] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
00:26:41.102 [info] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
00:26:41.102 [info] smsc95xx v1.0.6
00:26:41.178 [debug] Unknown property change: [“interface”, “eth0”, “present”]
old:
nil
new:
true
00:26:41.179 [debug] Unknown property change: [“interface”, “eth0”, “hw_path”]
old:
nil
new:
00:26:41.180 [debug] VintageNet(eth0): :retrying → eth0 up
00:26:41.181 [info] RouteManager: clear_route eth0
00:26:41.183 [info] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:b8:bd:5b
00:26:41.226 [info] Interface eth0 disconnected from access point
00:26:41.295 [info] Farmbot has been reconnected. Canceling scheduled factory reset
00:26:41.303 [info] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
00:26:41.322 [info] Child :udhcpc of Supervisor #PID<0.6858.0> (Supervisor.Default) started
Pid: #PID<0.6859.0>
Start Call: MuonTrap.Daemon.start_link(“udhcpc”, ["-f", “-i”, “eth0”, “-x”, “hostname:farmbot-00000000c6b8bd5b”, “-s”, “/srv/erlang/lib/vintage_net-0.9.3/priv/udhcpc_handler”], [stderr_to_stdout: true, log_output: :debug, log_prefix: "udhcpc(eth0): "])
Restart: :permanent
Shutdown: 500
Type: :worker
00:26:41.327 [debug] udhcpc(eth0): udhcpc: started, v1.32.0
00:26:41.327 [info] Child VintageNet.Interface.InternetConnectivityChecker of Supervisor #PID<0.6858.0> (Supervisor.Default) started
Pid: #PID<0.6860.0>
Start Call: VintageNet.Interface.InternetConnectivityChecker.start_link(“eth0”)
Restart: :permanent
Shutdown: 5000
Type: :worker
00:26:41.330 [info] eth0 dhcp deconfig: %{interface: “eth0”}
00:26:41.331 [info] Child :technology of Supervisor {VintageNet.Interface.Registry, {VintageNet.Interface.Supervisor, “eth0”}} started
Pid: #PID<0.6858.0>
Start Call: Supervisor.start_link([%{id: :udhcpc, restart: :permanent, shutdown: 500, start: {MuonTrap.Daemon, :start_link, [“udhcpc”, ["-f", “-i”, “eth0”, “-x”, “hostname:farmbot-00000000c6b8bd5b”, “-s”, “/srv/erlang/lib/vintage_net-0.9.3/priv/udhcpc_handler”], [stderr_to_stdout: true, log_output: :debug, log_prefix: "udhcpc(eth0): "]]}, type: :worker}, {VintageNet.Interface.InternetConnectivityChecker, “eth0”}], [strategy: :one_for_all])
Restart: :permanent
Shutdown: 5000
Type: :worker
00:26:41.332 [info] FarmBot will factory reset in 50 minutes if the network does not reassociate. If you see this message directly after configuration, this message can be safely ignored.
00:26:41.333 [debug] Unknown property change: [“interface”, “eth0”, “mac_address”]
old:
nil
new:
“b8:27:eb:b8:bd:5b”
00:26:41.333 [debug] Unknown property change: [“interface”, “eth0”, “state”]
old:
:retrying
new:
:configuring
00:26:41.334 [debug] Unknown property change: [“interface”, “eth0”, “state”]
old:
:configuring
new:
:configured
00:26:41.392 [debug] udhcpc(eth0): udhcpc: sending discover
00:26:41.483 [info] usb 1-1.2: new high-speed USB device number 30 using dwc_otg
00:26:41.762 [info] usb 1-1.2: new high-speed USB device number 31 using dwc_otg
00:26:41.862 [info] usb 1-1-port2: attempt power cycle
00:26:42.582 [info] usb 1-1.2: new high-speed USB device number 32 using dwc_otg
00:26:42.622 [info] usb 1-1.2: New USB device found, idVendor=1908, idProduct=2311, bcdDevice= 1.00
00:26:42.622 [info] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
00:26:42.623 [info] usb 1-1.2: Product: USB2.0 PC CAMERA
00:26:42.623 [info] usb 1-1.2: Manufacturer: Generic
00:26:42.623 [info] uvcvideo: Found UVC 1.00 device USB2.0 PC CAMERA (1908:2311)
00:26:42.623 [warn] uvcvideo 1-1.2:1.0: Entity type for entity Processing 2 was not initialized!
00:26:42.623 [warn] uvcvideo 1-1.2:1.0: Entity type for entity Camera 1 was not initialized!
00:26:42.624 [info] input: USB2.0 PC CAMERA: USB2.0 PC CAM as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input14
00:26:42.705 [info] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
00:26:42.705 [info] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xD1E1
00:26:42.742 [info] Interface eth0 connected access point
00:26:42.824 [info] Farmbot has been reconnected. Canceling scheduled factory reset
00:26:42.859 [info] Interface eth0 connected to local area network
00:26:42.924 [info] usb 1-1.5: new full-speed USB device number 33 using dwc_otg
00:26:43.059 [info] usb 1-1.5: New USB device found, idVendor=2341, idProduct=0042, bcdDevice= 0.01
00:26:43.060 [info] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=220
00:26:43.060 [info] usb 1-1.5: Manufacturer: Arduino (www.arduino.cc)
00:26:43.060 [info] usb 1-1.5: SerialNumber: 557353231363518182F0
00:26:43.061 [info] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
00:26:43.214 [debug] Unknown property change: [“interface”, “eth0”, “connection”]
old:
:lan
new:
:disconnected
00:26:43.453 [debug] firmware interface already detected: ttyACM0
00:26:44.043 [debug] Unknown property change: [“interface”, “eth0”, “addresses”]
old:
nil
new:
[%{address: {65152, 0, 0, 0, 47655, 60415, 65208, 48475}, family: :inet6, netmask: {65535, 65535, 65535, 65535, 0, 0, 0, 0}, prefix_length: 64, scope: :link}]
00:26:44.535 [debug] udhcpc(eth0): udhcpc: sending discover
00:26:44.672 [debug] udhcpc(eth0): udhcpc: sending select for 192.168.10.83
00:26:44.708 [info] usb 1-1.2: USB disconnect, device number 32
00:26:44.765 [debug] udhcpc(eth0): udhcpc: lease of 192.168.10.83 obtained, lease time 28800
00:26:44.766 [debug] udhcpc.renew(eth0): %{broadcast: “192.168.10.255”, dns: [“192.168.10.152”, “1.1.1.1”, “8.8.8.8”], domain: “sammamish.commune.local”, interface: “eth0”, ip: “192.168.10.83”, lease: “28800”, mask: “24”, opt53: “05”, router: [“192.168.10.1”], serverid: “192.168.10.1”, subnet: “255.255.255.0”}
00:26:44.778 [debug] Unknown property change: [“interface”, “eth0”, “addresses”]
old:
new:
00:26:44.784 [info] RouteManager: set_route eth0 → :lan
00:26:45.035 [info] Attempting to retrieve farmduino_k15 reset function.
00:26:45.064 [info] Using default reset function
00:26:45.100 [info] usb 1-1.2: new high-speed USB device number 34 using dwc_otg
00:26:45.232 [info] usb 1-1.2: New USB device found, idVendor=1908, idProduct=2311, bcdDevice= 1.00
00:26:45.232 [info] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
00:26:45.233 [info] usb 1-1.2: Product: USB2.0 PC CAMERA
00:26:45.233 [info] usb 1-1.2: Manufacturer: Generic
00:26:45.233 [info] uvcvideo: Found UVC 1.00 device USB2.0 PC CAMERA (1908:2311)
00:26:45.233 [warn] uvcvideo 1-1.2:1.0: Entity type for entity Processing 2 was not initialized!
00:26:45.233 [warn] uvcvideo 1-1.2:1.0: Entity type for entity Camera 1 was not initialized!
00:26:45.233 [info] input: USB2.0 PC CAMERA: USB2.0 PC CAM as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input15
00:26:46.026 [debug] still in state: :boot {:unknown, [<<254, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 254, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 254, 255, 255, 255, 255, 255, 255, 255, 255, …>>, “Serial”, “connection”, “started”]}
00:26:46.033 [debug] still in state: :boot {:report_parameter_value, [param_version: 1.0]}
00:26:46.034 [debug] still in state: :boot {:report_parameter_value, [param_config_ok: 0.0]}
00:26:46.034 [debug] still in state: :boot {:report_parameter_value, [param_use_eeprom: 1.0]}
00:26:46.038 [debug] still in state: :boot {:report_parameter_value, [param_e_stop_on_mov_err: 0.0]}
00:26:46.039 [debug] still in state: :boot {:report_parameter_value, [param_mov_nr_retry: 3.0]}
00:26:46.039 [debug] still in state: :boot {:report_parameter_value, [movement_timeout_x: 120.0]}
00:26:46.042 [debug] still in state: :boot {:report_parameter_value, [movement_timeout_y: 120.0]}
00:26:46.043 [debug] still in state: :boot {:report_parameter_value, [movement_timeout_z: 120.0]}
00:26:46.043 [debug] still in state: :boot {:report_parameter_value, [movement_keep_active_x: 0.0]}
00:26:46.046 [debug] still in state: :boot {:report_parameter_value, [movement_keep_active_y: 0.0]}
00:26:46.046 [debug] still in state: :boot {:report_parameter_value, [movement_keep_active_z: 1.0]}
00:26:46.046 [debug] still in state: :boot {:report_parameter_value, [movement_home_at_boot_x: 0.0]}
00:26:46.047 [debug] still in state: :boot {:report_parameter_value, [movement_home_at_boot_y: 0.0]}
00:26:46.051 [debug] still in state: :boot {:report_parameter_value, [movement_home_at_boot_z: 0.0]}
00:26:46.051 [debug] still in state: :boot {:report_parameter_value, [movement_invert_endpoints_x: 0.0]}
00:26:46.052 [debug] still in state: :boot {:report_parameter_value, [movement_invert_endpoints_y: 0.0]}
00:26:46.056 [debug] still in state: :boot {:report_parameter_value, [movement_invert_endpoints_z: 0.0]}
00:26:46.056 [debug] still in state: :boot {:report_parameter_value, [movement_enable_endpoints_x: 0.0]}
00:26:46.057 [debug] still in state: :boot {:report_parameter_value, [movement_enable_endpoints_y: 0.0]}
00:26:46.060 [debug] still in state: :boot {:report_parameter_value, [movement_enable_endpoints_z: 0.0]}
00:26:46.060 [debug] still in state: :boot {:report_parameter_value, [movement_invert_motor_x: 0.0]}
00:26:46.060 [debug] still in state: :boot {:report_parameter_value, [movement_invert_motor_y: 0.0]}
00:26:46.063 [debug] still in state: :boot {:report_parameter_value, [movement_invert_motor_z: 0.0]}
00:26:46.063 [debug] still in state: :boot {:report_parameter_value, [movement_secondary_motor_x: 1.0]}
00:26:46.064 [debug] still in state: :boot {:report_parameter_value, [movement_secondary_motor_invert_x: 1.0]}
00:26:46.067 [debug] still in state: :boot {:report_parameter_value, [movement_steps_acc_dec_x: 300.0]}
00:26:46.067 [debug] still in state: :boot {:report_parameter_value, [movement_steps_acc_dec_y: 300.0]}
00:26:46.068 [debug] still in state: :boot {:report_parameter_value, [movement_steps_acc_dec_z: 300.0]}
00:26:46.071 [debug] still in state: :boot {:report_parameter_value, [movement_stop_at_home_x: 0.0]}
00:26:46.071 [debug] still in state: :boot {:report_parameter_value, [movement_stop_at_home_y: 0.0]}
00:26:46.072 [debug] still in state: :boot {:report_parameter_value, [movement_stop_at_home_z: 0.0]}
00:26:46.072 [debug] still in state: :boot {:report_parameter_value, [movement_home_up_x: 0.0]}
00:26:46.075 [debug] still in state: :boot {:report_parameter_value, [movement_home_up_y: 0.0]}
00:26:46.075 [debug] still in state: :boot {:report_parameter_value, [movement_home_up_z: 1.0]}
00:26:46.075 [debug] still in state: :boot {:report_parameter_value, [movement_step_per_mm_x: 5.0]}
00:26:46.079 [debug] still in state: :boot {:report_parameter_value, [movement_step_per_mm_y: 5.0]}
00:26:46.079 [debug] still in state: :boot {:report_parameter_value, [movement_step_per_mm_z: 25.0]}
00:26:46.080 [debug] still in state: :boot {:report_parameter_value, [movement_min_spd_x: 50.0]}
00:26:46.083 [debug] still in state: :boot {:report_parameter_value, [movement_min_spd_y: 50.0]}
00:26:46.083 [debug] still in state: :boot {:report_parameter_value, [movement_min_spd_z: 50.0]}
00:26:46.084 [debug] still in state: :boot {:report_parameter_value, [movement_home_spd_x: 50.0]}
00:26:46.087 [debug] still in state: :boot {:report_parameter_value, [movement_home_spd_y: 50.0]}
00:26:46.087 [debug] still in state: :boot {:report_parameter_value, [movement_home_spd_z: 50.0]}
00:26:46.088 [debug] still in state: :boot {:report_parameter_value, [movement_max_spd_x: 400.0]}
00:26:46.092 [debug] still in state: :boot {:report_parameter_value, [movement_max_spd_y: 400.0]}
00:26:46.093 [debug] still in state: :boot {:report_parameter_value, [movement_max_spd_z: 400.0]}
00:26:46.093 [debug] still in state: :boot {:report_parameter_value, [movement_invert_2_endpoints_x: 0.0]}
00:26:46.095 [debug] still in state: :boot {:report_parameter_value, [movement_invert_2_endpoints_y: 0.0]}
00:26:46.095 [debug] still in state: :boot {:report_parameter_value, [movement_invert_2_endpoints_z: 0.0]}
00:26:46.095 [debug] still in state: :boot {:report_parameter_value, [movement_motor_current_x: 600.0]}
00:26:46.100 [debug] still in state: :boot {:report_parameter_value, [movement_motor_current_y: 600.0]}
00:26:46.100 [debug] still in state: :boot {:report_parameter_value, [movement_motor_current_z: 600.0]}
00:26:46.100 [debug] still in state: :boot {:report_parameter_value, [movement_stall_sensitivity_x: 30.0]}
00:26:46.103 [debug] still in state: :boot {:report_parameter_value, [movement_stall_sensitivity_y: 30.0]}
00:26:46.103 [debug] still in state: :boot {:report_parameter_value, [movement_stall_sensitivity_z: 30.0]}
00:26:46.104 [debug] still in state: :boot {:report_parameter_value, [movement_microsteps_x: 0.0]}
00:26:46.108 [debug] still in state: :boot {:report_parameter_value, [movement_microsteps_y: 0.0]}
00:26:46.108 [debug] still in state: :boot {:report_parameter_value, [movement_microsteps_z: 0.0]}
00:26:46.109 [debug] still in state: :boot {:report_parameter_value, [encoder_enabled_x: 0.0]}
00:26:46.113 [debug] still in state: :boot {:report_parameter_value, [encoder_enabled_y: 0.0]}
00:26:46.114 [debug] still in state: :boot {:report_parameter_value, [encoder_enabled_z: 0.0]}
00:26:46.114 [debug] still in state: :boot {:report_parameter_value, [encoder_type_x: 0.0]}
00:26:46.116 [debug] still in state: :boot {:report_parameter_value, [encoder_type_y: 0.0]}
00:26:46.116 [debug] still in state: :boot {:report_parameter_value, [encoder_type_z: 0.0]}
00:26:46.117 [debug] still in state: :boot {:report_parameter_value, [encoder_missed_steps_max_x: 5.0]}
00:26:46.120 [debug] still in state: :boot {:report_parameter_value, [encoder_missed_steps_max_y: 5.0]}
00:26:46.120 [debug] still in state: :boot {:report_parameter_value, [encoder_missed_steps_max_z: 5.0]}
00:26:46.121 [debug] still in state: :boot {:report_parameter_value, [encoder_scaling_x: 5556.0]}
00:26:46.124 [debug] still in state: :boot {:report_parameter_value, [encoder_scaling_y: 5556.0]}
00:26:46.124 [debug] still in state: :boot {:report_parameter_value, [encoder_scaling_z: 5556.0]}
00:26:46.128 [debug] still in state: :boot {:report_parameter_value, [encoder_missed_steps_decay_x: 5.0]}
00:26:46.129 [debug] still in state: :boot {:report_parameter_value, [encoder_missed_steps_decay_y: 5.0]}
00:26:46.129 [debug] still in state: :boot {:report_parameter_value, [encoder_missed_steps_decay_z: 5.0]}
00:26:46.132 [debug] still in state: :boot {:report_parameter_value, [encoder_use_for_pos_x: 0.0]}
00:26:46.133 [debug] still in state: :boot {:report_parameter_value, [encoder_use_for_pos_y: 0.0]}
00:26:46.133 [debug] still in state: :boot {:report_parameter_value, [encoder_use_for_pos_z: 0.0]}
00:26:46.136 [debug] still in state: :boot {:report_parameter_value, [encoder_invert_x: 0.0]}
00:26:46.136 [debug] still in state: :boot {:report_parameter_value, [encoder_invert_y: 0.0]}
00:26:46.137 [debug] still in state: :boot {:report_parameter_value, [encoder_invert_z: 0.0]}
00:26:46.140 [debug] still in state: :boot {:report_parameter_value, [movement_axis_nr_steps_x: 0.0]}
00:26:46.140 [debug] still in state: :boot {:report_parameter_value, [movement_axis_nr_steps_y: 0.0]}
00:26:46.141 [debug] still in state: :boot {:report_parameter_value, [movement_axis_nr_steps_z: 0.0]}
00:26:46.144 [debug] still in state: :boot {:report_parameter_value, [movement_stop_at_max_x: 0.0]}
00:26:46.145 [debug] still in state: :boot {:report_parameter_value, [movement_stop_at_max_y: 0.0]}
00:26:46.145 [debug] still in state: :boot {:report_parameter_value, [movement_stop_at_max_z: 0.0]}
00:26:46.149 [debug] still in state: :boot {:report_parameter_value, [pin_guard_1_pin_nr: 0.0]}
00:26:46.149 [debug] still in state: :boot {:report_parameter_value, [pin_guard_1_time_out: 60.0]}
00:26:46.149 [debug] still in state: :boot {:report_parameter_value, [pin_guard_1_active_state: 1.0]}
00:26:46.152 [debug] still in state: :boot {:report_parameter_value, [pin_guard_2_pin_nr: 0.0]}
00:26:46.153 [debug] still in state: :boot {:report_parameter_value, [pin_guard_2_time_out: 60.0]}
00:26:46.153 [debug] still in state: :boot {:report_parameter_value, [pin_guard_2_active_state: 1.0]}
00:26:46.157 [debug] still in state: :boot {:report_parameter_value, [pin_guard_3_pin_nr: 0.0]}
00:26:46.158 [debug] still in state: :boot {:report_parameter_value, [pin_guard_3_time_out: 60.0]}
00:26:46.158 [debug] still in state: :boot {:report_parameter_value, [pin_guard_3_active_state: 1.0]}
00:26:46.162 [debug] still in state: :boot {:report_parameter_value, [pin_guard_4_pin_nr: 0.0]}
00:26:46.163 [debug] still in state: :boot {:report_parameter_value, [pin_guard_4_time_out: 60.0]}
00:26:46.163 [debug] still in state: :boot {:report_parameter_value, [pin_guard_4_active_state: 1.0]}
00:26:46.166 [debug] still in state: :boot {:report_parameter_value, [pin_guard_5_pin_nr: 0.0]}
00:26:46.166 [debug] still in state: :boot {:report_parameter_value, [pin_guard_5_time_out: 60.0]}
00:26:46.167 [debug] still in state: :boot {:report_parameter_value, [pin_guard_5_active_state: 1.0]}
00:26:46.252 [info] RouteManager: set_connection_status eth0 → :internet
00:26:46.286 [debug] Unknown property change: [“interface”, “eth0”, “connection”]
old:
:disconnected
new:
:internet
00:26:46.585 [info] ARDUINO STARTUP COMPLETE (r99) transport=Elixir.FarmbotFirmware.UARTTransport
00:26:46.996 [debug] firmware state change: configuration => begin
00:26:49.139 [info] CeleryScript ok [#Reference<0.3272493800.537657345.39078>]:
00:27:09.478 [error] CeleryScript error [#Reference<0.3272493800.537657345.1920>]: “Firmware command: G00 X3.40 Y1050.00 Z0.00 A400.00 B400.00 C200.00 failed to respond within 30 seconds”
00:27:09.508 [info] Failed to execute command: Firmware command: G00 X3.40 Y1050.00 Z0.00 A400.00 B400.00 C200.00 failed to respond within 30 seconds
00:27:09.509 [error] CeleryScript error [#Reference<0.3272493800.537657345.1920>]: “Firmware command: G00 X3.40 Y1050.00 Z0.00 A400.00 B400.00 C200.00 failed to respond within 30 seconds”
00:27:09.727 [info] Child “1e654837-db50-49b3-9439-cb4c4ecf659a” of Supervisor FarmbotCore.AssetSupervisor.FarmbotCore.Asset.FarmwareEnv started
Pid: #PID<0.6873.0>
Start Call: FarmbotCore.AssetWorker.start_link(%FarmbotCore.Asset.FarmwareEnv{meta: #Ecto.Schema.Metadata<:loaded, “farmware_envs”>, created_at: ~U[2020-08-09 20:47:22.547000Z], id: 9701, key: “LAST_CLIENT_CONNECTED”, local_id: “1e654837-db50-49b3-9439-cb4c4ecf659a”, local_meta: #Ecto.Association.NotLoaded, monitor: true, updated_at: ~U[2021-04-04 00:26:51.614000Z], value: ““2021-04-04T00:26:47.517Z””})
Restart: :transient
Shutdown: 5000
Type: :worker
