Hi everyone
I’m currently work on a french project in Normandy region about development around the farmbot (plugins) and local network connection abilities.
In order to realize some connectivity tests, and because I’m in another region without physical farmbot, I try to install FarmbotOS (the rpi0 version found here) on a Raspi zero W without having farmduino connected on.
By using HDMI screen connected on rpi0, I can see that OS is running and passed some steps without any problem.
After a while, a warning error about “logging” appear (see attached image), quickly, and then Erlang is stopped. Finally the rpi0 is restarting, again and again …
Do you have any tricks for this problem ? Is it normal that a simple installation (with Etcher) of the image on my SD card (a transcend 8Go) not worked in my case ?
Thanks a lot for your help.
Thomas Berriot
