Hi guys! I am working on designing a Farmware script. As far I can see, I need to post it on Github (or something similar), but, can I do it without posting my code there? I mean, for example, having the code on my folder Documents.
Thank you!
Thank you!
FarmBot’s Raspberry Pi needs to be able to download the files. GitHub is one of the easier ways to do it, but any method that serves a file should work. If you are not on the same network as your FarmBot, you are limited to using public links instead of hosting the file yourself. You can use the private file features of many file sharing services to get a public link (private Gists, etc.).
Thank you! everything clear
