Currently the camera selection is stored in user_env of the bot state tree. In general, farmware_tools.device.set_user_env can be easily used from within a Farmware to modify user_env values. While verifying this was possible for this particular value, I created this Farmware.
wow, thanks a lot! I am just wondering - how can I possibly figure out what are the various user env values?
If I ran help(farmware_tools.device) from python console, I just got
set_user_env(key, value)
Send command: set_user_env.
Args:
key (str): ENV key
value (str): ENV value
If I understood it right, farmware is executed on FB’s raspberry pi is that right? I would like to “play” with my farmware code in my IDE (pycharm) and only then upload it and try excuting it on my bot - is this possible?
You can see all the values by viewing them in the bot state. One way to do this is via the JavaScript console in the browser: store.getState().bot.hardware.user_env. In the future, these values will be stored in the API and available via HTTP.
