FB just weirded out
I just experienced the weirdest ‘water all’ sequence ever.
24 plants. It watered 3 successfully, moved to the fourth and started watering when the Z axis dropped, so with the water still turned on, it moved Y to 0, washing out the seed trays on the gantry. It then moved back to the fourth plant location - or so I thought when the Y lined up, it then moved X to 0 and watered there (where there is no plant). After this, it moved to plant 5 and continued successfully.
This indicates to me that the underlying code is not coded in a fail safe manner. This kind of strangeness should not happen. I know we are not on a mars mission so ‘nothing happened’ but still. I went to export the log files but that does not seem possible through the existing mechanisms.
Meh
