I ended up getting this working very crudely with a node module called “node-gamepad” and a USB game controller I purchased on Amazon some time ago for RetroPie. It’s heavily based upon the tutorial that @RickCarlino posted below. I am definitely not a career programmer so I’m sure there are more efficient/proper ways to code this so I’m definitely open to constructive criticism.
EDIT I was not able to upload the file so I will copy and paste it below
// FarmBotJS requires a global atob() function for
// decoding tokens. In NodeJS, we must add a polyfill.
// To learn more about the issue, see:
// https://github.com/FarmBot/farmbot-js/issues/33
var GamePad = require( ‘node-gamepad’ );
var controller = new GamePad( ‘snes/retrolink’, {
vendorID: 2064,
productID: 58625
controller.connect();
global.atob = require(“atob”);
// Set default move amount to 1 mm
var moveAmount = 1;
// Now that we have access to atob(), we can load
// FarmbotJS, a Farmbot client.
// NodeJS uses CommonJS modules. You can learn more
// about CommonJS here:
// https://flaviocopes.com/commonjs/
// The first library we will load is FarmBotJS.
// Using FarmBotJS is a smart idea because it is
// the same wrapper library used by FarmBot, Inc.
// to control FarmBot. Using it ensures that your
// application will remain compatibile with future
// FarmBot OS versions.
// Learn more about it here:
const Farmbot = require(“farmbot”).Farmbot;
// We will need an HTTP client in order to create
// a FarmBot authorization token.
// Learn more about tokens here:
// https://developer.farm.bot/docs/rest-api#section-generating-an-api-token
// Learn more about Axios the HTTP client here:
// https://github.com/axios/axios
const post = require(“axios”).post;
// Now that we have loaded all the third party libraries,
// Let’s store some application config as constants.
// We need this information to create an auth token
// and also to log in to the FarmBot server so that
// we can remote control the device.
const PASSWORD =
const EMAIL =
const SERVER =
// We will also store some application state in an
// object known as “APPLICATION_STATE”.
const APPLICATION_STATE = {
// This object will be populated later,
// after we connect to the server.
// Please see the FarmBotJS documentation for
// more information about what the FarmBot object
// can do.
farmbot: undefined,
// This application is trivial- it just moves the
// Z-axis up and down. We will keep track of that
// here.
direction: “up”,
// The correct way to track FarmBot’s busy state
// is via Javascript “Promises”. Promises are beyond
// the scope of this example, so we will just use
// a simple boolean flag.
// If you don’t know what promises are, YouTube
// tutorials are a good place to start.
// Promises are tricky to learn at first, but
// will make your code very clean once you understand
// them.
// https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Promise
busy: false
// The function below will be used to extract a JSON
// Web Token (JWT) from the Farmbot server. It is
// a callback that will be used by an HTTP POST
// request by Axios later. Continue reading to learn more.
const tokenOK = (response) => {
console.log("GOT TOKEN: " + response.data.token.encoded);
return response.data.token.encoded;
// This is a generic error handler. We will use it
// to catch miscellaneous “promise rejections”.
// Check out egghead.io and YouTube to learn more
// about Javascript promises.
const errorHandler = (error) => {
console.log("=== ERROR ===");
console.dir(error);
// This function will perform an HTTP post and
// resolve a promise that contains a FarmBot auth
// token (string).
// Call this function with an email and password
const createToken = (email, password) => {
const payload = { user: { email, password } };
return post(SERVER + “/api/tokens”, payload).then(tokenOK);
// This function is called exactly once at the start
// of the application lifecycle.
const start = () => {
// Perform an HTTP reqeust to create a token:
return createToken(EMAIL, PASSWORD)
// Pass the token to FarmBotJS so that we
// can connect ot the server:
.then((token) => {
// Set the global FarmBot object instance for the entire app.
APPLICATION_STATE.farmbot = new Farmbot({ token: token });
// Were ready to connect!
return APPLICATION_STATE.farmbot.connect();
// Once we are connected to the server,
// we can display a helpful message.
.then(() => { console.log(“CONNECTED TO FARMBOT!”); })
// If anything goes wrong, throw the error to
// our error handler function.
.catch(errorHandler);
if (PASSWORD && EMAIL) {
// It is important to use promises here-
// The run loop won’t start until we are finished
// connecting t the server. If we don’t do this,
// the app might try to send commands before we
// are connected to the server
start()
// Set move amount to 1 mm
controller.on( 'y:press', function () {
moveAmount = 1;
console.log("Move amount set to 1 mm");
// Set move amount to 10 mm
controller.on( 'x:press', function () {
moveAmount = 10;
console.log("Move amount set to 10 mm");
// Set move amount to 100 mm
controller.on( 'b:press', function () {
moveAmount = 100;
console.log("Move amount set to 100 mm");
// Set move amount to 1000 mm
controller.on( 'a:press', function () {
moveAmount = 1000;
console.log("Move amount set to 1000 mm");
// Move FarmBot x-axis up
controller.on( 'up:press', function() {
if (APPLICATION_STATE.busy) {
console.log("FarmBot is currently busy.");
return;
} else {
APPLICATION_STATE.busy = true;
APPLICATION_STATE
.farmbot
.moveRelative({ x: -moveAmount, y: 0, z: 0 })
.then(() => {
APPLICATION_STATE.direction = "up";
APPLICATION_STATE.busy = false;
// Move FarmBot x-axis down
controller.on( 'down:press', function() {
return;
} else {
APPLICATION_STATE
.farmbot
.moveRelative({ x: moveAmount, y: 0, z: 0 })
.then(() => {
APPLICATION_STATE.direction = "down";
// Move FarmBot y-axis right
controller.on( 'right:press', function() {
return;
} else {
APPLICATION_STATE
.farmbot
.moveRelative({ x: 0, y: moveAmount, z: 0 })
.then(() => {
APPLICATION_STATE.direction = "right";
// Move FarmBot y-axis left
controller.on( 'left:press', function() {
return;
} else {
APPLICATION_STATE
.farmbot
.moveRelative({ x: 0, y: -moveAmount, z: 0 })
.then(() => {
APPLICATION_STATE.direction = "left";
// Move FarmBot z-axis down
controller.on( 'r:press', function() {
return;
} else {
APPLICATION_STATE
.farmbot
.moveRelative({ x: 0, y: 0, z: -moveAmount })
.then(() => {
APPLICATION_STATE.direction = "zdown";
// Move FarmBot z-axis up
return;
} else {
APPLICATION_STATE
.farmbot
.moveRelative({ x: 0, y: 0, z: moveAmount })
.then(() => {
APPLICATION_STATE.direction = "zup";
} else {
// You should not see this message if your .env file is correct:
throw new Error(“You did not set FARMBOT_EMAIL or FARMBOT_PASSWORD in the .env file.”);
