Groups Not Appearing in DropDown Menu
I’ve seen posts from a while back…and there have been updates that make them obsolete so I’m perplexed…I’m trying to make a sequence to water a group of plants, but the groups are not available in the drop down menu when trying to add a variable. Very frustrating as I created a similar sequence last year without problems
Hi @AndyPCDS yes, I think I see the same “issue” . .
During Sequence creation, I want to add a Location variable and give it a Default value of one of my Plant Groups . . I don’t see any Groups at all in the dropdown list, so I give it the value None.
Now I can Run this sequence manually and get an input dialogue window where I do see my Groups !
I believe that Location Variables which are Externally defined in a sequence require this sequence to be executed by a “higher level” sequence which assigns a chosen Plant Group to that variable name before beginning the “subordinate” sequence execution.
E.g. Look at the FarmBot Featured Sequence Water Using Curve.
There’s good documentation on Sequence Variables over at
Externally Defined Variables | FarmBot Software Documentation
