Help - Replacement tube (x-axis 4.5m)
My water tube on the x-axis (4.5m) has burst. Luckily I was around and able to shut off the water before any major flooding happened.
The 4.5m tube is out of stock on Farmbot’s shop. I bought a PVC tube locally (6mm internal diameter) but it leaks near the barb adapter. I then managed to find a 6mm internal / 10mm external silicon tube but it balloons out when I open the water.
Does anyone have any recommendation as to where I could find the right type of tube in Switzerland?
