is any one know how to write the defult SSID and password into raspberry Pi!
becaus the wifi is always discontected and after e-stop is not to re contect the wifi !is very Bad
Hey @ardun
I would recommend to unplug your farmbot from power and plug it back in. If it won’t connect or open the configuration WiFi within a few minutes, you need to flash the sdcard again.
There are currently known issues with the connection. Hopefully those will be fixed in the next update.
can you tell me when will have update?!
I’m sorry but I can’t give you further information when the next update will be released. The software developers are working hard to get it out asap.
@ardun, v4.0.0 software was released last week. You can read about the improvements here. We also just published v4.0.1 a few hours ago. After updating, do you still have the same issues?
when i update the 4.0 ,the wifi is work good ,but i didn’t use end-stop!
