We updated my.farmbot.io and FarmBot OS today with the following new features and fixes:
App:
- Fixed bug that limited the ability to disable internationalization. (Thanks Klimbim for the bug report.)
- Improved recovery from loading errors.
Farm Designer:
- Change icons for plants selected for deletion to grayscale.
- Render toolbay slots in the garden map if a slot orientation is selected for the slot on the Tools page.
Device:
- Gray out parameters that are not used unless enabled by a different parameter. For example, encoder options are grayed out if encoders are disabled.
- Fixed bugs related to device connectivity display.
Sequences:
- Display a warning if the current hardware settings conflict with
Find HomeorMove Absolutestep inputs. Hover over the warning symbol for additional information. - Added
Speakchannel to sequenceSend Messagecommands. If selected, FarmBot will speak the message over the audio port.
Tools:
- Added toolbay slot orientation selection dropdown menu. This and the use current location feature have been moved into a toolbay slot options pop-up menu.
FarmBot OS (v6.1.2):
- Send an email if FarmBot has been emergency stopped for more than 10 minutes.
- Improved movement complete response time (Thanks Klimbim for the bug report.)
- Misc. OS update bug fixes.
