January 7, 2026 Software Update
Hello all and Happy New Year! This year kicks off with another software update now live for the FarmBot web app. Here’s what’s new:
3D spread spheres
Now when the SPREAD map layer is turned on, you’ll see semi-translucent green spread spheres around every plant in the 3D farm designer beta. Just like the old 2D spread rings, the spheres represent the maximum expected space the plant will take up once matured, allowing you to better plan your garden layout.
In addition to the green spheres, white spread spheres are now shown as a preview when adding new plants to the garden individually or as part of a grid or row.
And finally, spread spheres will show as red when they are:
  • Extended beyond the inside edges of the bed with tracks (which can cause machine interference)
  • Too close to X=0 (where toolbays are typically located)
  • Extended above the bottom of the gantry main beam
  • When a new plant being added would have an overlapping spread
Improved grid and row planting
The grid and row planting popup got a big performance boost: it now renders the preview 5x faster. This allowed us to increase the number of plants you can add at once from 100 to 200.
We also removed the preview toggle, favoring always-on previews to save you a click. And finally, the popup now stays open even when clicking out of it (to move the 3D view, for example). To actually close it, click the cancel button.
Coming soon…
In the next update you can expect 3D visualizations of the camera’s view as well as animations for when FarmBot is taking photos, performing calibration, measuring soil height, and detecting weeds. Stay tuned!
Thank you @roryaronson for your hard work and the constant improvements you and your team deliver with every release! Happy New Year and all the best! :partying_face:
I’ve run into an issue: when using my iPhone, both Safari and Chrome crash immediately upon loading the new my.farm.bot site. I suspect it may be related to the 3D view.
Since all iOS browsers utilize Apple’s WebKit engine, the issue persists across Chrome, Firefox, and Safari. The console log outputs:
A few questions/suggestions:
  • Are you able to reproduce this crash on your end? I know Safari is not intended to be supported, but for small tasks it would be very helpful.
  • Would it be possible to add a toggle to set the default view mode (e.g., forcing 2D on load)?
Side note: I experienced a similar issue with the September 5th release, where the JavaScript engine crashed specifically when opening the movements menu.
Safari on a MacBook?
When using Safari on a MacBook the my.farm.bot site runs without any issues!
Just let me know If you need additional information.
Thanks!
