Hi, I did my best to run my own mqtt-gateway.
Shortly: did someone run it in 2022 or still using it? I really need help with “Error starting Mosca Server”.
It seems this code comes from farmbot team. I have no idea why they did this in nodejs but OK is it cold be helpfull then no problem.
But it is not very helpful.
First nodejs build errors. Last work on this was in 2017. So in combination with nodejs is this quite problem - ubuntu 22 respectively. It does match nothing so I got nice error generator. Finally I found nodejs version 8 match. And the build was done with last error whis I solved with help from stackoverflow.
So can I be happy, no. I see another obscure error:
honza@honza-VirtualBox:~/mqtt-gateway$ WEB_API_URL=http://localhost:3000 sudo npm start
[sudo] password for honza:
> farmbot-mqtt-gateway@1.1.0 start /home/honza/mqtt-gateway
> nodemon ./app/index.js
[nodemon] 1.19.4
[nodemon] to restart at any time, enter `rs`
[nodemon] watching dir(s): *.*
[nodemon] watching extensions: js,mjs,json
[nodemon] starting `node ./app/index.js`
Using http://localhost:3000 as API URL
{"pid":10241,"hostname":"honza-VirtualBox","name":"mosca","level":50,"time":1662391106351,"msg":"Error starting Mosca Server","v":1}
events.js:183
throw er; // Unhandled 'error' event
Error: listen EADDRINUSE :::1883
at Object._errnoException (util.js:1022:11)
at _exceptionWithHostPort (util.js:1044:20)
at Server.setupListenHandle [as _listen2] (net.js:1367:14)
at listenInCluster (net.js:1408:12)
at Server.listen (net.js:1492:7)
at /home/honza/mqtt-gateway/node_modules/mosca/lib/server.js:225:16
at makeCall (/home/honza/mqtt-gateway/node_modules/fastseries/series.js:119:7)
at NoResultsHolder.release (/home/honza/mqtt-gateway/node_modules/fastseries/series.js:67:9)
at series (/home/honza/mqtt-gateway/node_modules/fastseries/series.js:39:14)
at Object.eachSeries (/home/honza/mqtt-gateway/node_modules/steed/steed.js:47:5)
at Server.steed.series.logInfo (/home/honza/mqtt-gateway/node_modules/mosca/lib/server.js:211:13)
at makeCall (/home/honza/mqtt-gateway/node_modules/fastseries/series.js:117:7)
at ResultsHolder.release (/home/honza/mqtt-gateway/node_modules/fastseries/series.js:96:9)
at Server.steed.series.steed.eachSeries.fallback (/home/honza/mqtt-gateway/node_modules/mosca/lib/server.js:204:9)
at /home/honza/mqtt-gateway/node_modules/ascoltatori/lib/ascoltatori.js:93:9
at TrieAscoltatore.<anonymous> (/home/honza/mqtt-gateway/node_modules/ascoltatori/lib/abstract_ascoltatore.js:61:7)
at emitTwo (events.js:126:13)
at TrieAscoltatore.emit (events.js:214:7)
at _addListener (events.js:249:14)
at TrieAscoltatore.addListener (events.js:297:10)
[nodemon] app crashed - waiting for file changes before starting...
Did someone see this error. Has someone idea what is going on?
Thanks, Jan
