I’m currently in the process of coding a Lua sequence to fetch data from my Netatmo Weather Station (https://www.netatmo.com/smart-rain-gauge).
Unfortunately it is a bit tricky to implement, since the requests have to be made with a proper oauth accesstoken.
As long as I do have a valid access token I’m able to fetch data from the Netatmo API.
Since the Netatmo accesstoken at somepoint expires, I need to fetch a new access token via the refreshtoken. See documentation: Netatmo Connect | Authentication
For this api call I have to send a POST Request. Unfortunately this is the problematic part I’m currently stuck.
I’m unable to set the http content-type to:
Content-Type: application/x-www-form-urlencoded;charset=UTF-8
Question: Could it be that the http function only supports application/json?
My code
should fetch a new accesstoken in case the regular requests no more deliver data:
device_id = "xyz"
request_url = "https://api.netatmo.com/api/getstationsdata?device_id=" .. device_id .. "&get_favorites=false"
netatmo_accesstoken = env("netatmo_accesstoken")
-- fake access token to force, wrong token...
--netatmo_accesstoken = "sdfasfasdf"
netatmo_refreshtoken = env("netatmo_refreshtoken")
netatmo_clientid = env("netatmo_clientid")
netatmo_clientsecret = env("netatmo_clientsecret")
toast(netatmo_refreshtoken)
toast(netatmo_accesstoken)
toast(netatmo_clientid)
toast(netatmo_clientsecret)
env("netatmo_rain_mm_24h")
toast("Getting data from " .. request_url)
response, error = http({
url=request_url,
headers={
Authorization='Bearer ' .. netatmo_accesstoken,
Accept="application/json"
if error then
send_message("info", "Unknown error: " .. inspect(error))
else
-- The `response` object has three properties:
-- `status`: Number - Response code. Example: 200.
-- `body`: String - Response body. Always a string.
-- `headers`: Map<String, String> - Response headers.
end
toast(response.status)
toast(inspect(response.headers))
-- toast(payload)
if response.status > 400 then
--send_message("warning", "Netatmo api response was error 401, accesstoken probably expired. Fetching a new one.")
url='https://api.netatmo.com/oauth2/token',
method="POST",
headers={
Content-Type="application/x-www-form-urlencoded;charset=UTF-8"
body="client_id=xyz&client_secret=xyz&grant_type=refresh_token&refresh_token=xyz"
if error then
-- The `error` object is reserved for non-HTTP errors.
-- Example: missing URL.
-- `error` will be `nil` if no issues are found.
send_message("info", "Use of refreshtoken failed, error: " .. inspect(error))
else
end
toast(response.headers)
toast(response.body)
refreshtoken_response = json.decode(response.body)
send_message("info", "Refreshtoken response: " .. refreshtoken_response)
env("netatmo_refreshtoken", refreshtoken_response.refresh_token)
env("netatmo_accesstoken", refreshtoken_response.access_token)
else
toast("Access token is still valid")
end
netatmo_data = json.decode(response.body)
rain_mm_24h = netatmo_data.body.devices[1].modules[3].dashboard_data.sum_rain_24
toast("Netatmo messured rain in the last 24hours: " .. tostring(rain_mm_24h) .. "mm")
send_message("info", "Netatmo messured rain in the last 24hours: " .. tostring(rain_mm_24h) .. "mm")
-- Store it in Variable
env("netatmo_rain_mm_24h", tostring(rain_mm_24h))
I’ve tried to set the Content-Type in the headers… But this produces a Lua Error:
Failed to execute command: Lua code is possibly invalid: [{51, :luerl_parse, [~c"syntax error before: “, ~c”‘=’"]}]
For reference:
Fetching a new accesstoken via Postman works:
Fetching it in Postman with application/json will as expected fail too:
Thanks for some inputs in advance ![]()
