Picture of the watering tool after a few weeks outside, doesn’t bode well.
Looks like nickel plated neodymium magnets aren’t suitable for water, should be zinc, epoxy or plastic
coated
coated
Ive noticed the same.
Wait till you see the “stainless steel” bolts start to rust. They will of course. And they will change their impedance significantly over time. Wouldn’t want to use them for low voltage or dc electrical conductors either. Gold plated contacts are the only way to go with water and open air humidity.
A simple web search for suitable materials would have picked up dozens of articles on the magnets and the SS selected as well as many of the other parts in the kit:
https://www.supermagnete.de/eng/faq/Can-I-use-magnets-outdoors-as-well
http://www.whatareneodymiummagnets.com/faqs.html
https://www.quora.com/Does-neodymium-rusthttp://www.duramag.com/neodymium-magnets-ndfeb/corrosion-resistance-of-neodymium-magnets/
etc.
Stainless Steel:
https://www.theruststore.com/Can-stainless-steel-rust-W71.aspx
etc.
@Loveny @jonweisw I have noticed the same thing happen when I’ve dropped the tool in the soil and some particles with iron in it attracted to the magnets and rusted. Are you able to just wipe off the rust? I know that sounds kind of ridiculous but in my experience that rust is only the soil particles rusting and can be wiped clean off of the magnets.
good point about the iron from other sources rusting. that will certainly happen and should be cleaned from the surface with a mild solvent. I’ve found that chrome rust cleaner from a car shop works well.
however, magnets do and will rust unless they are coated in a rust proof coating. they are available with such coatings. perhaps you could look into that for future revisions of the kit.
As pointed out in some of the links from @bgmoon, the nickel plating is supposed to protect the magnets from rusting, though it looks like the nickel plating is damaged on that magnet and causing it to start rusting. @Loveny may I send you some replacements? If so, just email me at rory@farmbot.io with your preferred shipping address
For future kits we’ll look at a plastic or rubber coating that will hopefully be less susceptible to damage like this.
You are kind, but that’s not my system - That’s Loveny’s
I was just trying to help him understand how they would rust.
@bgmoon, haha yes I knew that
My response and offer was to @Loveny, though perhaps I guess I wasn’t clear enough
Will update my post!
Yea, I guess the “reply” came to me because you probably hight the “reply” button on my post rather than the one on Loveny’s post
It happens, I was just trying to connect your comment back to the right party.
