I am considering having a play with making a laser weeder, but I don’t know how much current I can draw from the UTM. It appears that 24 V is available on pins E and H, but I cannot see how much current can be safely draw.
Is there somewhere, where I can get this information?
Probably one for Rory to confirm, but I start with the Farmduino schematic . . see what current each Peripheral power MOSFET can handle, check the common wire Fuse value, etc.
Answer is it’ll depend on total max concurrent load added on the other peripherals.
There are other discussions in this forum about this and worth searching for.
I think the PCB trace size limits the continuous Imax.
