Hello, i’m having an issue that happened right after i auto calibrate the Farmbot. The encoder is working fine and the motors is working fine too.
After the calibration proccess done, the motor wont stop and keep hitting the stopper until i press the e-stop button, so i never saw the “calibration in X done” in my log, instead i got “calibration X: idle”
The same thing happened when i press “go to home” button. They keep going but not at the full speed. This problem happened in all axis.
Two troubleshooting tips that may help identify the issue:
What are your encoder settings (in the Hardware widget), and what are the resolutions of your motors and encoders?
What position is reported in the Controls page Move widget when the axis end is reached? (You can display encoder positions as well if you haven’t done so already using the Move widget settings menu.)
