I am using an mqtt connection to send commands to the farmbot with celeryscript. Everything worked fine yesterday when i left, but this morning i noticed that my farmbot wouldn’t receive any mqtt commands anymore. I also didn’t receive the subscribed messages back from the farmbot. ’
This is my current situation:
I can control the farmbot using the webapp
When connecting to the farmbot using mqtt (in python) i get result code 0, which should mean that there is a connection
My my client doesn’t disconnect, i programmed that a message would show up in the console on farmbotclient.on_disconnect
The backup i made a week earlier (which definitly worked) doesn’t work anymore
My guess is that this is a hardware related problem, but i’m not sure, does anyone know what the problem could be or what to look for?
We recently switched message brokers. If you use token_data['token']['unencoded']['mqtt'] for the broker address in client.connect(), you should be able to communicate with FarmBot again.
I’m still not sure what to change when you say to use: token_data[‘token’][‘unencoded’][‘mqtt’] for the broker address in client.connect(). Do you have a small example on how to connect in python with the new RabbitMQ?
