We need to make the FarmBot work urgently.
We connected FarmBot (genesis v1.3) to the internet with a wired Ethernet connection.
But we can’t see the farmbot network appear in our wifi connections so we can set it up.
Do you have any trick knowing that we updated the software to v9 and we are in an event where the FarmBot is near lots of other heavy duty electrical equipment.
Wired Ethernet with “static” IPv4 addressing needs a recent Farmbot OS ( e.g. v9.1.1 )
The Farmbot Configurator Wi-Fi Access Point will only appear after
a) Factory Reset of a version that was running from that SD card.
b) Booting a freshly flashed SD card first time
May I suggest flashing v9.1.2 onto a known good SD card and trying once again ?
( I did just this myself today and proved that static wired Ethernet configuration works )
Hi @jsimmonds
Thanks for your answer.
I did the update (9.11…9.12), but unfornatly I don’t have any wifi between the FB and my iphone / compute/ other cellphone
By the way, it was the same situation yesterday with the 9.1.1 version
Thanks for your help
I think we have to take time to find a solution for our next show.
I’ve observed that the farmbot-xxxx Wi-Fi SSID can take up to 3 minutes to appear ( 2.4GHz band only )
Did you wait 3 minutes or longer ?
What were the red and green LEDs on the Raspberry Pi board doing ?
[ A good Factory Reset situation is ( after boot finish ) : red solid, green brief flashes every so-often ( while user configuration completes via the FBOS Configurator web-site )
Thanks for your time @jsimmonds
The farmbot is “on” all the time, I start/stop him offently till 2 days but nothing happen :
The red light is not flashing
The green light is not flashing
On my Iphone, when I search “manual” farmbot-xxxx", no network appears
Its the same when I do it with the FB process : no FB on wifi networks
Did anybody else meet this kind of situation during an exhibition like us ? And what was your solution ?
Do you think the FB wifi network could be disturbed by the other network around us ?
When he’s back to “his” home, everything is ok. So I think the problem is not the card.
Other question : could it be possible to move the robot directly from an iphone with a single shedule without going trough the server, just for our exhibition and to show how it moves
Thanks all for your help
Stéphane
We are showing the FarmBot in Paris, during the biggest event around agriculture in France, it is called SIA : Salon International de l’Agriculture
We are on the innovation space of the Agriculture Chamber of Normandy. Our front neibourgh is the public french tv France 3
You’re welcome
I have found some devices don’t pick up the FB wifi but it sounds like you have tried a few so I don’t think that’s the problem.
Can you see other wifi networks?
Is your wifi network a home or an organisational network?
A few people have had problems connecting to the FB because their organisational wifi networks are locked down by their network administrators. So if that’s the case I would ask your network admin for help.
Note I also have to wait for 1-3mins before the FB wifi network appears after I have flashed a new card or factory reset.
@Stephane . . quite possible. Can you use a wired ( physical ) Ethernet connection ?
I do not, but I imagine these people do : @roryaronson and @RickCarlino I hope that they can help find a solution at that exhibition. The Wi-Fi spectrum there must be very dense.
Hi @whitecaps and @jsimmonds
The problem appears at the first connection between the FB and us, just when I need to inform him where it must connect itself ( wifi or ethernet)
I can see on my phone, all the other network around me.
I used an ethernet connection 2 days ago but it was the same : the problem is at the first wifi connection when I have to inform the FB on witch network it had to be connected (wifi-ethernet)
Do you think it could be possible to plug directly my iphone on one usb port for the first connection ? So perhaps could the FB be directly connected on 4G. I will try it tomorrow morning
Ahh, yes . . I realised after I had posted that we usually need Wi-Fi first . . but
If you can find good Network support from Exhibitor Coordinator/Support, then the following might help.
Note that if you could connect wired Ethernet to a small private switch, you could configure FBOS over Ethernet by browsing to IPv4 address 192.168.25.1
If you have a Raspberry Pi TTL to USB Serial cable you can talk to FBOS , e.g.
could it be possible to move the robot directly from an iPhone
We don’t support USB tethering currently, only WiFi tethering unfortunately.
Here are some ideas on why a WiFi portal does not appear:
If you did not burn a new image to the SD Card (moved FarmBot with current SD Card): you may need to enable “Automatic Factory Reset”. Unfortunately, FarmBot needs to be online for the setting to take effect, so it would be easier to burn a new FBOS image onto the SD Card.
If you did burn a new FBOS image: You may have flashed the wrong FBOS version onto the SD Card. Example: Accidentally running FBOS Express on a Genesis device. If this is the case, the device will not load at all. Check https://os.farm.bot for the latest version and ensure the image you download matches the model you purchased.
Here are some less likely scenarios:
There is software at the event that views your device as a threat and is interfering with the device’s WiFi because it thinks it is a “rogue access point”. I have never seen this personally, but have received reports from some customers (usually at schools / universities)
The device was damaged in transit. If this is the case, you may be able to purchase a new RPi device locally.
Some things you can try:
Unscrew the Raspberry Pi from the case and move out of the building to verify that it is the WiFi hotspot and not some other factor.
Unfortunately, it is difficult to diagnose these issues without logs.
Hi Rick and John,
thanks for your help and responses, we’re back to the office today, the FB is alwas on exhibition in Paris till the 1er march but still out of order. When It will be back here, we will work on it and trying your solutions.
By the way, the 3D glasses and Microphone from of our neighbour on this event didn’t work at all.
Our next job will be to find the fault and therefore the solution to make it work in a disturbed area.
We keep you informed, thanks to all,
Stéphane
