Seems like a bug:
- Create new sequence.
- Add
Move
command, location Seed Bin
, Z offset 100
- Add
Move
command, location Offset from current position
, disable X/Y axes, Z offset -50
- Save the sequence, wait for sync.
- Second move command updates to
Custom coordinates
Expected behaviour would be to keep the Offset from current position
because if the first move command location ever changes, the second move command’s absolute coordinates don’t make sense anymore. They need to stay relative to the first move command.
Before sync:
After sync:
Is the actual behaviour of the second MOVE
correct ?
( despite the move block showing Custom Coordinates )
Two other questions
- The first
MOVE
statement has SAFE Z
checked, the second one unchecked. Does that make a difference ?
- Why
Disable axis
for X and Y versus leaving OFFSET
both 0 ?
It is. Seems like a UI bug.
Toggling safe Z doesn’t resolve the bug for me.
Why disable axis? It makes more sense semantically (to me) but it’s a matter of personal preference I guess.
I will let Gabriel know about this on Monday, @mdingena. I will let you know what we find out.
@mdingena We have added this bug to the backlog. Thanks for the heads up.
