@RickCarlino I have some periferals on the Farmduino digital pins that worked in OSv7 but I am unable to turn the digital pins on and off in OSv8.
When I try to turn the pin on in the controls tab I just get a message saying the pin 2 peripheral value is off but the software doesn’t switch the pin to on.
@whitecaps, I’m using FBOS 8.2.0 and I can see an issue with Digital Pin 2 in the WebApp UI (Controls tab). The pin appears to be stuck ON but the firmware commands from FBOS to the Farmduino v1.4 appear to be correctly commanding the pin toggle.
In the screen capture below, I am using NEW PERIPHERAL
Maybe one for the Dev. team ( e.g. @RickCarlino ) to help sort out ?
