I tried configuring the farmbot using a network which did not provide good enough connection. I am trying to get access to the configure page again to choose a new network but the farmbot network does not show up in the available networks when searching for using wifi. Can you please help?
Hi Gabriel and thanks for your reply. The farmbot has never been synced and that is why I am trying to configure it again using a different network. The device widget Just shows that the device has never been connected and does not have many of the functions as a result.
Thanks for your help. I think that did the trick. So what I did this time was to run a cable for Ethernet which is connected now but The farmbit Web app still says the machine is not connected.
The farmbot network does not show up when searching for Wifi networks which I think means that configuration has gone through.
Your help is much appreciated.
