I’m having an issue with my watering sequence. It’s not working correctly. As you can see, it should be following the order of my plants, but it’s skipping some. I applied the beta to see if that would fix the problem but it didn’t
@stre1026 That is very strange. What is your device ID? Please leave the device online while I take a look (I may need to remotely inspect it)
Hi @RickCarlino
Thanks. It’s 11807
As a side note: it would cool if you had a spot in the profile of this forum to be able to put the device ID so you could just refer to it if you wanted to. Just a thought!
@stre1026 Taking a look now.
Our forum software supports this. We can add it.
@stre1026 I need to ask more specific questions about your account. I will move the discussion to PM.
Thanks @RickCarlino
I’ve added mine!
