Regarding the problem of power outage and inability to reconnect
I’ve encountered this issue several times. After powering off and then powering on again, the device won’t automatically connect to Wi-Fi. I have to reconfigure it by flashing the SD card. Based on the stability of Wi-Fi, I have the following suggestions. I’m not sure if they’re feasible.
Can the built-in Wi-Fi detection or Wi-Fi configuration information be improved?
  1. Once Wi-Fi information is written, it becomes read-only and can only be rewritten through the configuration window. Otherwise, the configuration remains read-only.
  2. Add a Wi-Fi loss reconfiguration mechanism, such as a loop that checks for Wi-Fi availability and automatically restores the hotspot configuration if it’s unavailable. Reconfiguration can then be performed through the hotspot.
  3. Add a Wi-Fi information backup and restore mechanism. If Wi-Fi is unavailable, the device can first be restored through the Wi-Fi recovery mechanism and then reconfigured through the Wi-Fi loss reconfiguration mechanism.
This should ensure quick Wi-Fi connection recovery.
