I have been stress-testing my FB because of the weird things I am seeing and I found a bit of an issue.
I accidentally clicked ‘run’ on the dismount_tool() sequence twice in under a second. What I saw was a bit of a worry in that both commands were processed instead of FB declaring a conflict.
The FB
- Lifted Z to Zero.
- Moved to the correct XY location to dismount the tool.
- Lowered Z to the correct height to insert the tool into the rack
- Moved X into the correct tool destination location.
- Moved X out back to the dismount entry position
- Moved Z up to dismount.
FB sort of merged the two launched sequences together.
This make me wonder if there is thread launch protection and what happens if you are using the FB and a scheduled script launches.
It is repeatable and if you press it three times, it enters the slot three times.
Can someone else please test my observations.
