Seeding - Thoughts and ideas
One of the bigger ones.
Ok I mostly use the smallest needle. I would check your suction power and there is no blockages. Have you tried what I suggested?
Without trying what you suggest (suppose you’re referring to the cleaning), I tested the suction power. There is no problem there. I think I’ll try to compile a video of my observations. That might give a better understanding of what I am observing. But is it correctly understood that picking up seeds works perfectly for you?
No not perfectly. I don’t often plant 45+ seeds at a time usually max 10-15 and that usually works. If it doesn’t I go through the steps I told you.
Question because I don’t own an Express. Do you have any any spare periferal ports on it?
It would be great to see a video @jensGeorgsen.
Has anyone tried adding a small suction cup on the end of the needle? I’ve seen these used for SMT soldering, for example. They come in a variety of sizes. This is a ā€œlargerā€ from Zeph:
apk6
http://www.zeph.com/zt3web.htm
I’ve had similar experiences to the ones in this discussion and I saw that someone else has published a tool also. I didn’t see that previously and I’ve created a digging tool and a hole filling tools and published them on Thingiverse. Hope they are useful to some of you.
Jack
Great work. Pity I have an Express. I may need to upgrade it if seeding doesn’t work properly.
Thank you. The improvement was dramatic for me. Its nice to see the seeds dropping directly into the hole.
