Hello! I’m going to have 2 soil moisture sensors in my garden bed and then I wanted to create sequences that will check the sensor and then decided whether or not to water the plants that day. If once I input my plants on the map and put each sensors sector into a group could I use the “water plant” sequence and select the sensors’ corresponding group to get watered, would that work?
Smart idea, since you can the moisture at a bit more depth into account. I think what you are planning to do will work fine, I think i would combine them in one sequence that will run daily. For location you can just select your plant group.
