During which step of the FarmBot Configurator instructions does the issue occur? After a successful configuration, the FarmBot’s WiFi network should disappear because it will connect to the WIFi network provided. Does it disappear before you can submit the credentials in FarmBot Configurator? Or does it not connect to the WiFi network you provide after its own “farmbot-xxxx” network disappears?
Information that can be helpful to include when describing a problem:
- Version (In this case, which FarmBotOS release?)
- Steps to reproduce the problem
- Expected results
