My Farmbot Genesis v1.6 must take its water supply from a water barrel. Fortunately the perfect mod is described at https://genesis.farm.bot/v1.6/extras/mods/capture-and-use-rainwater… except the mod is for the original Farmbot with the RAMPS shield which uses 12V. The Farmduino board uses 24V.
I plan to connect the water pump to one of the spare peripheral ports on Farmduino and wondered if anyone can recommend a suitable 24V pump please?
That 7A5 fuse covers sum of all peripherals simultaneous load.
Each peripheral’s current limit is the limit of the Power MOSFET controlling it.
The schematics have the MOSFET part number and it’s easy to find that part’s max. current
edit
@captainsemtex keep in mind that the total current budget of the Genesis power supply is 6A25 ! Power Supply | FarmBot Genesis Documentation
If you’re just using the Farmduino Peripheral to control a pump relay then that should be Ok.
