I removed the existing solenoid as it was only suitable for main water pressure.
I replaced it with a low-pressure 24 V solenoid and 24 V water pump so I could use a water butt. It worked perfectly. …but…
There is something that has appeared which I did not expect. Brownness of the piping.
The original hose remains perfectly clear but the two types of tubing I purchased from Amazon.co.uk have both gone brown. One slightly so and one very much so. This I did not anticipate. There must be a UV sensitivity or something like that.
Any ideas anyone?
