Simply put, anytime I try to POST/GET the /tokens endpoint, it states I haven’t authenticated when obviously I need to hit this endpoint for authentication (i.e. getting my JSON web token).
Is this because of maintenance that I did not know about?
link: https://my.farm.bot/api/tokens
output:
"error": "You failed to authenticate with the API. Ensure that you provide a JSON Web Token in the `Authorization:` header."
