Hi everyone!
I’m trying to create an automated sequence using Lua script, but the documentation is not very helpful.
I’m stuck at trying to get the position of the Seed Trough 1, I can’t find in documentation anything related to getting the position of a specific tool.
Here’s my script. I’m trying to get the value for tray_coordinates.
Be aware that this is a Work in progress. The code is in a non-functional state.
grid_points = variable("Number of points")
cell_depth = 15
vacuum_pump_pin = 9
seed_depth = env("planting_depth")
-- tray_coordinates = get_coordinate("Seed trough 1") -- LOOK HERE!!!!
if verify_tool() then
send_message("info", "Dismounting tool")
dismount_tool()
end
send_message("info", "Mounting Seeder tool")
mount_tool("Seeder")
local grid = grid ({
grid_points = grid_points,
start = variable("Starting location"),
spacing = variable("Spacing")
job = "Pick and Plant x" .. grid.total
toast("Executing Pick and Plant sequence on a " ..
grid_points.x .. " x " .. grid_points.y ..
" grid with " .. grid.total .. " points.")
grid.each(function(cell)
-- Move above tray
send_message("info", "Moving above seed tray cell " .. cell_label .. tray_coordinates)
move_absolute({
x = tray_cell.x,
y = tray_cell.y,
z = tray_cell.z + 25,
safe_z = true
send_message("info", "Lowering to pick up seed from " .. tray_coordinates)
move_absolute({
x = tray_cell.x,
y = tray_cell.y,
z = tray_cell.z - cell_depth,
safe_z = true
send_message("info", "Activating vacuum pump")
write_pin(vacuum_pump_pin, "digital", 1) -- Turn on vacuum pump
-- Wait briefly to ensure suction
wait(500)
-- Move up with the seed
send_message("info", "Lifting seed")
move_absolute({
x = tray_cell.x,
y = tray_cell.y,
safe_z = true
-- Move to planting location
local grid_point_coordinates = "(" .. cell.x .. ", " .. cell.y .. ", " .. cell.z .. ")"
send_message("info", "Moving to planting location " .. grid_point_coordinates)
move_absolute(cell.x, cell.y, cell.z)
-- Lower to plant
send_message("info", "Lowering to plant seed")
move_absolute({
x = cell.x,
y = cell.y,
z = cell.z - 5, -- Lower slightly to ensure seed lands properly
safe_z = true
-- Deactivate vacuum to release seed
send_message("info", "Releasing seed")
write_pin(vacuum_pump_pin, "digital", 0) -- Turn off vacuum pump
-- Wait briefly to ensure release
wait(500)
-- Move up after planting
send_message("info", "Lifting after planting")
move_absolute({
x = cell.x,
y = cell.y,
z = cell.z + 25,
safe_z = true
end)
complete_job(job)
Thanks for helping
