After i set up 4.0. i can not control motor x,y,z .
                Ascend
                    June 25, 2017, 11:06am
                  2
              When does this error appear? In a sequence or by moving manually in the controls tab?
As you can see in the following thread, some other users also had this issue and fixed it by changing the retries in your hardware settings to a higher number.
    Everything seems to work well, except that my existing master sequence fails halfway through: FAILED TO EXECUTE MOVE_ABSOLUTE: FAILED TO MOVE TO: (400, 1030, 200). This was a sequence that has been working fine with previous versions. It is actually a sequence composed of many ‘execute’ commands for other sequences which operate on rows. I’ve changed the timeout values with no success. I can remove some of the execute sequences and the process proceeds further, but always stops after a certain a…
              Please use the 4.0.0 update thread for any issues that arose after upgrading to this version.
