Hello,
It’s look like there is a missing bit of info in the doc. When you look at https://genesis.farmbot.io/v1.3/docs/z-axis-cable-carrier
You are told to put the following cables and tube in the cable carrier :
Step 3: Lay out the tube and wiring
Keeping the mounting orientation of the cable carrier in mind, lay the UTM cable, the water tube, the camera cable, and the z-axis motor and encoder cables into the open cable carrier.
Nowhere you are told to put the vaccum pump power cable… did anybody notice it already ?
Side question : Can’t we just update doc ourselves somewhere ?
