UTM mounting & dismounting tool for each seed in a group
I have a sequence to mount a tool (seeder) - no problem
i have a sequence to dismount a tool - no problem
i have a sequence to plant a seed (as externally defined variable) - no problem.
They all work individually.
When i combine the 3 using ‘execute sequence’ and plant a group, the UTM will get the tool, plant one seed, dismount the tool, mount the tool, plant another seed, dismount again and so on, one by one!
if i remove the mount and dismount commands it plants them all without issues.
ive followed the documentation (Plant Your First Garden | FarmBot Software Documentation) to a tee, as far as i can tell.
What am i doing wrong?
Any ideas how to fix this?
Hope someone can help.
Thank you
